kyocera km-8030 error C4200
  • kibbs
    • Apr 2013
    • 94
    [Error Code] kyocera km-8030 error C4200
    Dear Friends,
    i have one Kyocera KM 8030 machine in customer side.. before i was facing C4000 errror and i order and change new laser unit.. after that i was facing this error C4200. Please give some quick solution for this issue guys...
    Regards
    Kibbs
  • Zackuth
    • Aug 2009
    • 448
    Re: kyocera km-8030 error C4200
    Before you change the laser, try changing the charge grid. I had a machine throwing a laser code, I don't remember which one exactly, and that was the solution. I found that solution on an older post on the site.
    If at first you don't succeed, redefine success
    • rnrfisherman
      I have had main charge arcing cause this code... good luck and let us know what you find!!
        • 22999
        Any kind of high voltage arcing can give you the C4200 errors. See below:
        "C4200" error message, 163 times. Clears. Arcing primary charge unit. Replace primary charge unit. Also may need drum replacement.
        "C4200" intermittently. Error clears, then returns after a few copies/prints. Transfer charge arcing at the ground contact causes logic errors. Rebuild/replace transfer belt assembly (302FB93061). See QA Service Bulletin 7393.
        "C4200" intermittently. Error clears, then returns after a few copies/prints. The laser unit harnass has been re-routed, as in later production. Install new style laser unit harnass per QA Service Bulletin 8619.
        "C4200" intermittently. Error clears, then returns after a few copies/prints. Pre-transfer corona cleaner becomes jammed, shorting the pre-transfer charge. Repair/replace the pre-transfer charge unit.
        "C4200" intermittently. Error clears, then returns after a few copies/prints. Developer bias arcing at the imaging unit contact causes logic errors. Replace developer bias contact.
        "Copying Stopped 4200" or "Turn Power Off/On 4200" intermittently. Error clears, then returns after a few copies/prints. No error is stored in the service error log. Developer bias making poor contact at the imaging unit contact causing logic errors. Clean any conductive grease from the developer bias contact.
        "C4200" & "C0630" intermittently. Error clears, then returns after a few copies/prints. Paper outputs face up to tray B regardless of default settings (can be temporarily reset with U906 partial reset). Developer bias arcing at the imaging unit contact causes logic errors. Replace developer bias contact (302FB08481).
