Taskalfa 180 weired Problem!!!!!!
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    [Electrical] Taskalfa 180 weired Problem!!!!!!
    Hi to all
    i've problem with TASKALFA 180 when i turn power ON machine does't marche , i hear just the FAN move abit , But they displaying nothing in the screen , i've replaced new POWER SUPPLY but No result!
    how i can resolve this problem!!!
    Thank you in advance.
    Best regards.
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
    • 23009
    Re: Taskalfa 180 weired Problem!!!!!!
    Start with firmware (not farmwear). =^..^=
    • sweet.persona
      Engineer
      • Nov 2009
      • 414
      thank you very much our Prof , but i miss the steps to upgrade the FrimwAre , can you tech me the steps!
      DAMENE ABDEL AZIZ
      DJELFA
        • 23009
        Sure:
        1) download firmware from KDA Connect
        2) format 128MB CF card on same model
        3) extract firmware
        4) copy extracted files to the root of the CF card
        5) power Off MFP
        6) insert CF card
        7) power On MFP
        8) be patient! it can take up to 45 minutes to load firmware.
        9) when complete power Off
        10) power Off
        11) remove CF card
        12) power On
        • sweet.persona
          Engineer
          • Nov 2009
          • 414
          Lot of thankx to you d&ar Prof Blackcat , you've sipmly and perfect style to Interpretation of information i want to got just 10% from ur mind to be Great engineer !
          Best Regards
          DAMENE ABDEL AZIZ
          DJELFA
            • 23009
            Your welcome. May I safely conclude that your issue is resolved? =^..^=
            • sweet.persona
              Engineer
              • Nov 2009
              • 414
              thank you dear Balckat , now i've the CF card and i've the Firmware but where's the PORT to connect the CF card exactly!!
              pls i need your reply (maybe with Pic show it exactly)
              thank you in advance.
              Best Regards.
              DAMENE ABDEL AZIZ
              DJELFA
              • sweet.persona
                Engineer
                • Nov 2009
                • 414
                I need ur help D&ar Blackat , the costumer of his machine called me Between 20 at 35 time in my phone and i don't want to Raise the banner of surrender ^^
                DAMENE ABDEL AZIZ
                DJELFA
                • JustManuals
                  • Jan 2006
                  • 9838
                  Maybe if you looked at your service manual you could help yourself..........
                    • 23009
                    You'll need an inexpensive card reader something like this. There are many different kinds:
                    Amazon.com: PQI USB 2.0 CompactFlash (CF) Card Reader: PRECISION DESIGN: Computers & Accessories
                    • madas
                      • Aug 2008
                      • 313
                      Had you done any work on the machine before this fault appeared?
                      reason I ask is you may have trapped a wire and that is causing the problem? only a suggestion.
                      madas
