need Mita DC1860 fuser unit or M.K. + heat lamp
  • axyun
    • Aug 2007
    • 1323
    Need Mita DC1860 fuser unit or maintenance kit and heater lamp. Machine is hooked up to Jamex 4300 coin op and I need to repair or hook up another machine with manufacturer interface harness. Any help or suggestions are appreciated. Frank/ActionPhotocopy
    If you are local enough I could buy a working Mita DC1560,1860,2360...Copystar 2115,2218,2221
  • 10871087
    • Jan 2005
    • 1062
    Re: need Mita DC1860 fuser unit or M.K. + heat lamp
    Parts were discontinued years ago, time for a new copier.
    • axyun
      • Aug 2007
      • 1323
      I agree. The problem is machine is connected to Jamex 4300 coin-op which customer wants to keep. So any replacement machine will need to be hooked up to it. Small pharmacy unlikely to spend couple thaousant for replacement machine with another coin-op.
      My options are rebuild DC1860 fuser with new lamp + Mk or replace with other machine that Jamex 4300 accomodates. Looking into Sharp harnesses like DVENDPG + DVENDAG but not able to get them so far. Frank
      • JR2ALTA
        • Feb 2010
        • 2033
        If the Jamex is not compatible with a new machine they will sell you an updated control board not a whole new coin op
        • axyun
          • Aug 2007
          • 1323
          Thank you JR. Frank
