F248 code on terminal servers
  • bronco31
    • Aug 2009
    • 174
    F248 CODE my entire install of FS4200 printers at an escrow office is on thin clients/Terminal servers?im running ver 9 firm, the small Uni KPDL driver ver 8, on hosted W2K8 R2 terminal server...shd i try the big KX ver 6 driver on KPDL passthru? (i was told its too resource intensive for a Terminal server session over a WAN)im getting intermitant (once a week) F248 codes.. printer frozen, jobs backed up, cranky escrow officers then yelling, "our old HP didnt do that!"
    • 23010
    Re: F248 code on terminal servers
    You know, of course, that CF248 errors are print data errors. The cause can be a specific document, an application, a driver, or just non-print data being sent to a printer. The hard part is to find the source of your corrupt print jobs, maybe one of those left over HP print drivers still being used to print to a Kyocera. And start out with the Macs first. The MacIntosh laptops seem to be more prone to this. =^..^=
    • bronco31
      • Aug 2009
      • 174
      hey BC...hows everybody out there on CTNet? the quirks and problems never end do they!
      well with only thin-client devices (running RDP on Linux i suppose) in this office, theres not going be any stray PCs printing to that IP with wrong drivers...no Macs either...
      its definitely coming from a valid print job ...some PDF they print..then F248, frozen printer.
      come to think of it.. i have "Auto-Error Clear On" , i think in 30 seconds, wonder why it freezes without self clearing?
      should i switch to the PCL version of the Uni Driver?
      i saw something about using the KX ver6 driver with PDL set to KPDL with "data pass thru" on..
      but Kyo tech support says no, the KX driver isnt best for TS over a WAN..
      problem is always in contacting the TS hosting company to make changes to the print driver on their server...a slow process
      what id like is Kyo Japan to solve this code via firmware or driver...
      • krakcy
        • Nov 2013
        • 19
        I had this problem with case ware accounting software!What i did is 1) set the machine as primary emulation to AUTO and Alternative to PCL 2) Case ware does not support PCL or GDI they say we mast use RPLC (Kyocera does not have RPCL Driver) Use PCL5e or PCL5c form the drivers/device setings/PDL
        • bronco31
          • Aug 2009
          • 174
          on these Terminal Servers, im not using the KX driver where you can choose what PDL to use...
