Task Alfa 3050ci Firmware error
  • Larhal
    • 564
    [Error Code] Task Alfa 3050ci Firmware error
    Hi A,
    I had a TA 3050ci which the Ops PWB went out. Replaced it and went to load the firmware in but it would not take. Did a boot from the Ops PWB using the boot switch and re tried to load the firmware.
    When I did it started the load but came up with and error - panel and a message: Master file: DL_panl.2K3 or DL_panl.2KZ or DL_panl.2LC not found.
    Checked the firmware and it was on there (DL_panl.2lc). Tried older firmware and no luck still get error.
    NOTE: after I end the firmware load and re boot it comes up again with a F000 fault so I have to reboot from the OPS panel.
    Kyocera guys said faulty OPS PWB so I replaced again with a known good one and the same thing happened. Also tried a known good Main PWB and still had the problems.
    Any Ideas????
    Thanks Larhal
    Larhal
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
  • habik
    • 2013
    Re: Task Alfa 3050ci Firmware error
    Try different USB memory key
    THere was a post somewhere here on the forum about the USB being not recognised and to be without any security files loaded after you format it!
    Firmwares HERE
    • Larhal
      • 564
      The USB stick was formatted fat and was OK as I had used it to load firmware on other machines of this series. It is starting the firmware update but has an error on the firmware for the operations panel.
      Larhal
      • habik
        • 2013
        FAT 32 it has to be
        Firmwares HERE
        • Larhal
          • 564
          Well I got a new memory stick, reformatted fat 32, loaded the firmware on it and still the same error message.
          Anyone any ideas?
          Larhal
          Larhal
          • darry1322
            • Oct 2010
            • 817
            Have you tried using the usb port on the back of the machine where the network connection is located?
            • luis8832
              • Dec 2008
              • 250
              you can use the usb port where the network connection is or if you want remove the back cover and use a cf card. The slot is there in the back of the unit.
              • jchithiya
                hi, i am having the same problem, can anyone help me
                How did you sort the machine out larhlal
                • Larhal
                  • 564
                  Had to send the Main and engine eprom back to Kyocera and have them re flashed.
                  Larhal
                  Larhal
