Kyocera TaskAlfa 3050 CI close front cover
  • Froggy
    • 14
    [Error Code] Kyocera TaskAlfa 3050 CI close front cover
    Hello everybody.
    Sorry for my bad english.
    I have got a problem.
    A week ago the machine of our customer give the code: C4301
    I have changed the engine board from another machine, but that was not the solution.
    I've ordered an new LSU. Then i changed the LSU, and the machine works.!!!
    Then i placed the engine board back in the other machine, but after that, the machine says: close right cover.
    I have checked all conectors and now the machines says: close front cover.
    WHAT DO I WRONG???
    • 22999
    Re: Kyocera TaskAlfa 3050 CI close front cover
    My guess is that you still have a connection problem. You probably noticed that some of those connectors are very difficult to remove. It's possible that with all the tugging you may have pulled free a couple of the individual leads from one of the connectors.
    The thing to do is to crack open the manual, and track down which connector goes to the door interlocks, and which individual pins. Then examine that connector, and pin out (measure the resistance) through the interlock switch from that main board connector. =^..^=
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • Froggy
        • 14
        Hello Blackcat,
        Thanks for your response.
        It was one of the flat cables !!!
          • 22999
          Congratulations Froggy. =^..^=
