I have a customer with a Kyocera 2551ci with a fax (W) B fitted. The fax is on the same phone line as a PDQ machine. Is there anyway of changing settings on the fax so these 2 devices do not conflict when dialing in/out? Again Sales told the customer it would be ok and the engineer would get it working!! Brilliant. Over to you Guys!!
Fax vs PDQ machine
Tags: None
Re: Fax vs PDQ machine
Always plug phone line to fax IN jack and external device to EXT jack on the fax, then your fax will say line in use when external device is communicatingIBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications -
Other than that devices like faxes and credit card machines that communicate over the phone line are dumb. They make several, sometimes erroneous assumptions:
1) They assume that if the fax (or whatever) is not online, then the line is available.
2) They assume that they are the only device on the phone line.
As a result, it's like having a rude, too-drunk party guest. He's talks too loud, right over everyone else's conversation, and never listens.
Two or more devices on the same phone line routinely try to talk over each other, resulting in errors for all three or four devices (if you include two senders and two receivers). The only way to get full functionality for both devices is to have then on separate dedicated phone lines. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Use a com switch 7500 from command Communications. Both devices plug into it as well as the phone line , the device will regulate line use and direct in comming calls to the correct device.Mystic Crystal RevelationsComment
