kyocera 250ci specs of color
  • oldtech1
    • Mar 2008
    • 35
    random specs of color are on copies and prints? latest firmware ,ran drum and developer refresh.
    • 23009
    Re: kyocera 250ci specs of color
    Are we maybe talking about the donut dots? Tiny specks of magenta, cyan, yellow, and/or black with a pattern that re-occurs at 96.75mm intervals? For whichever color the dots are, the primary charge roller has arced to that drum in millions of tiny places.
    First:
    1) identify the color of the specks.
    2) replace those drum unit(s)
    3) upgrade firmware to version 11 or higher, I believe we're currently at version 13.
    4) perform color calibration.
    • rashid120
      • Jun 2010
      • 76
      Please replace the Drum..which color you are facing problem..cyan.magenta,yellow or black.
      thanks and regards.
      • oldtech1
        • Mar 2008
        • 35
        First:
        they are not the donuts. just specs of different colors and locations on the copies or prints
        • Jules Winfield
          • Jul 2009
          • 821
          Try cleaning the transfer cleaning roller...
          But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
            • 23009
            ... with a pattern that re-occurs at 96.75mm intervals? ...
            And you measured?
            • bronco31
              • Aug 2009
              • 174
              why am i still seeing this problem even @ver13 firm?
              • Zackuth
                • Aug 2009
                • 448
                It could be that the motor that powers the transfer belt cleaning assembly is dead. An easy way to check this is to see if the MP tray works or not, as both are powered by the same motor.
                If at first you don't succeed, redefine success
                • BHRLC
                  • Nov 2013
                  • 77
                  So it's not one of the DLP units going bad?
                  The troubleshooting guide for this series from Kyocera states to perform AC calibration(s)
                  and if that doesn't work, replace the DLP unit associated with it's respective dot errors, etc...
                  I've been working on alot of 300ci's lately and the more reading I do about them, the more
                  troublesome this series seems.
