KM4035 problem
  • AlleyCat Copiers
    • Jun 2025
    KM4035 problem
    • 22999
    Re: KM4035 problem
    Typically there is a simulation to calibrate the width VR. What the machine does is store values for two positions. I'll see if I can find the sim for you. =^..^=
    • AlleyCat Copiers
      Re: KM4035 problem
      Thanks for the reply. That would be great if thats all I need.
      Will
      • JustManuals
        • Jan 2006
        • 9838
        Re: KM4035 problem
        Paul@justmanuals.com
        • AlleyCat Copiers
          Re: KM4035 problem
          Will
          Blackcat4866 Have you had any luck finding a simulation to reset the numbers on the RADF2 slide rails, Will
          • AlleyCat Copiers
            Re: KM4035 problem
            I am still wondering if someone knows how to reset the VR numerical numbers for the SRDF2. The doc feeder does not read 8.5x11 paper. When sidrails are move they rewad form 144 to 256 when they should read 49 to 256.
            Will
              • 22999
              Re: KM4035 problem
              That VR is supposed to vary from 49 when closed to 256 fully open.
              At 8 1/2" width you should be seeing 50 to 146
              At 11" width you should be seeing 197.632 to 197.720
              It's common for those VRs to develop corrosion, and when you slide the guides outward the values can jump around, or drop off completely. You'll probably end up replacing the VR. On this model, I don't see a sim to calibrate the VR.
              Sorry for the slow response. =^..^=
