kyocera 250Ci Document Box password forget
  • kibbs
    • Apr 2013
    • 94
    Dear all,
    How to reset the document box password. because i forget the document box password.. some important file are their in that document box.. how do i get that..
    Thanks & Regards
    kibbs
    • 22927
    Re: kyocera 250Ci Document Box password forget
    You can forget about recovering the documents. Without the password they'll stay right where they are. About the only think you can do to permanently delete passworded document boxes is a U020 all clear. =^..^=
    • kibbs
      • Apr 2013
      • 94
      omg..!! is thier any way from the prescribe command to find or reset the password...
      • CWP
        • Jun 2013
        • 168
        Is the password on a Document Box or Custom Box? There is a big difference, and if it is a Custom Box you are using, you should be able to retrieve the document.
        • kibbs
          • Apr 2013
          • 94
          Custom box i think.. inside Document box i create one folder with the password...
          • CWP
            • Jun 2013
            • 168
            If you turn on local authentication and then log in with an administrator account, you should be able to change the password on the Custom Box, then manipulate or download the documents that are stored in it, even after turning authentication back off.
            • kibbs
              • Apr 2013
              • 94
              thanks alot.. its works for me...!! Customer happy, me too happy coz of ur solutions..
