Kyocera Taskalfa 520i c6000 error
  • kibbs
    • Apr 2013
    • 94
    Dear friends,
    i am facing problem in taskalfa 520i C6000 fixing unit error.. i change the fixing unit.. then i reset by 163 and then switch off and On. then also machine getting c6000 error. i reset disable function then it looks same C6000 error...
    Thanks & Regards
    kibbs
  • zeeeba
    • Dec 2012
    • 58
    Re: Kyocera Taskalfa 520i c6000 error
    Try to Check main power supply unit
      • 23009
      Did you install a KM-5050 fuser? They're not the same. =^..^=
      • kibbs
        • Apr 2013
        • 94
        i don't think like that.. we took the correct part only...
          • 23009
          If the power supply doesn't help, or even if it does, check the grounding of the outlet your MFP is plugged into. You could have a zero-cross situation. =^..^=
