cyan was weak after long runs so i swapped out the dev unit, the usual routine, vacuum out all the ducts, box in back etc, then upgrade from ver 5 to 6
a week later all the drums have snapped gears (the little paddle that connects to the auger)
the end/exit of the cleaning auger of the drums have hard toner nuggets/pebbles!
the auger is unable to turn thus the small gear train on the back of each drum (under a white plastic cover) starts skipping or snaps.
whats did i do or is this coincidence ? why the hard toner jamming up the drum cleaning auger?
when i vacuum i can HEAR the pebbles bouncing up my vacuum hose!
i replaced the drums but issue comes back
internal temps and room temp all normal
yes the whole mod kit was installed
any help advice appreciated!
