Taskalfa 5501 c2550 error code
  • Max
    • Oct 2011
    • 575
    Apparently a paper feed motor problem. The paper feed motor runs fine in sim mode but error code comes up after 10 seconds or so.I have tried the motor from the bottom 2 trays still the same.Re connected the connectors on control board still the same. The ribbon cable are way too small to check for continuity so Im sort of leaning towards the ribbon cable. Checked the gearbox and the clutches, nothing sticking all running fine.Any one else had something similar?
    • 23010
    Re: Taskalfa 5501 c2550 error code
    If it runs in simulation mode, I would not blame the ribbon. I would think you've got am over-current condition because:
    1) the motor is overloaded: drive too difficult to turn.
    or 2) the motor is drawing too much current due to motor failure.
    If you can do it, I would remove the motor but leave it connected electrically. If it turns and doesn't error immediately look at the drive. If it does not turn look at the motor.
    • Max
      • Oct 2011
      • 575
      Tried it on the different motor out of the copier sill the same.
      • Venom
        Technical/IT Support
        • Nov 2009
        • 765
        I have seen transfer belt motor fail, otherwise could be transfer unit.
        IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
        • FINGERS123
          • Nov 2012
          • 33
          Remove the transfer belt on the conveying section there is a ground on the foot that gets blacken from toner chaging on it and causes that wacky code also clean the contact on back of transfer belt.
          • Max
            • Oct 2011
            • 575
            Turned out to be the complete transfer belt assembly.
