Kyocera FS-1370DN Command Center password
  • tonyk
    • Dec 2013
    • 8
    I've bought a used Kyocera FS-1370DN printer. The Command center's password is missing. I've already tried the admin00, Admin00, etc. passwords without any success.
    Is there any way to reset this unknown password?
  • madas
    • Aug 2008
    • 313
    Re: Kyocera FS-1370DN Command Center password
    If you have 2 boxes it is user name Admin password Admin
    madas
    • tonyk
      • Dec 2013
      • 8
      No, I've one box only for the password.
        • 23007
        The password for the FS-1370 is defaulted to: no authentication
        The best solution is to find the jerk that changed the authentication setting, and have that person enter the password.
        Second choice: Engine Reset PreSribe command.
        • tonyk
          • Dec 2013
          • 8
          This printer is coming from another country, so it's impossible to find who changed the password.
          Of course, I tried to log in with blank password: no success
          I also tried the engine reset ( !R! EGRE;EXIT; ) over telnet (port 9100), and with GCC File Send Utility, but nothing happens.
          The DATA led is blinking, "Processing" message on the display for couple of minutes.
          • BHRLC
            • Nov 2013
            • 77
            try admin00
            (zero zero)
            • tonyk
              • Dec 2013
              • 8
              Originally posted by BHRLC
              try admin00
              (zero zero)
              Thx! But I've already tried it. (as you can see in the first post)
              • BHRLC
                • Nov 2013
                • 77
                I meant with lowercase "a"...
                • tonyk
                  • Dec 2013
                  • 8
                  Thx!
                  From the first post:
                    Is the command center password changed along with the RUI admin password?..I don't know, I don't use the command center.
                    This might be worth a go.
                    Find Ip address of printer and log into the RUI.
                    Login as admin "admin00"
                    Then look for advanced and reset to defaults.
                    Restart the printer
                    Good Luck.
                    • tonyk
                      • Dec 2013
                      • 8
                      Thanks!
                      Sorry, but what is the RUI ?
                        Thanks!
                        Sorry mate ignore that post RUI is what some manufacturers call Remote User Interface, Kyocera call RUI = Command Center.
                        There must be some way of resetting this without ordering a new main board...
                        There was a tool by Kyocera called resetlan.exe,
                        You can find it here
                          Also there's talk of some jumper settings here,
                          • tonyk
                            • Dec 2013
                            • 8
                            Thanks! I've already tried it.
                            edit - Jumper:
                            I've also tried it.
                            Ther is no jumper on the 1370DN's mainboard, and the network "card" is not removable. The interface integrated to the mainboard.
                              Try this thread
                              http://www.copytechnet.com/forums/sh...eset-procedure
