system error f425 Kyocera
Re: system error f425 Kyocera
In this case we are having maybe internal communication error.
I know F423 means Fax controlling error/ broken Fax PWB.
Do you have FAX (U) installed? I yet, remove it at first and check again.
Your LEDs are flashing very fast/ too fast for normal operation.
Maybe controlling error between operation panel <--> main pwb, or controlling shortcut because of faulty Fax 8U).
I think without exchange from one or more pwbs you won`t solve this problem.Comment
At one of the Russian technical forum users had the same problem, it helped to download the software via USBComment
Overwriting from FW without "ES-SKIP.on" file sometimes can be helpfull.
Before exchange from any pwbs i prefer to run FW overwriting at first.
But you must be carefull, if one component inside is broken, there is the possibilty to get "Stucking in FW upgrade" with error code like "0801" or else.
We also have had this at Hanabi range because of broken adress book on main pwb on danish market. because of wrong language packet.........
It`s not possible for you to delete the faulty adress book, this must be done by debugger tool from KYO technician.Comment
Now i watched your video again and
You had written wrong CF code!!
System shows F245 instead of F425!!!
Please have a look for Bulletin F165_COM_347
You need special reset Main FW to solve it.
79MB is too big for sending by mail.
I attach the bulletin and you must download the reset file from KYO webpage.Attached FilesComment
