are kyocera 250ci toner compatibile with UTAX CDC-1725??
  • mrbu
    Hello, i want to buy a kyocera 250ci, but i find a UTAX CDC-1725 from germany at good price, and the retailers tell me it's the same machine (utax 250ci and UTAX CDC-1725) with another name.
    I'm italian and here the utax brand is not more famous, it's difficult to find the toner from national shop.
    the question is: can i use kyocera 250ci toner on the
    UTAX CDC-1725 ??
    and the parts like finisher, drum ecc.. it's the same of kyocera??
    thank you very much and sorry for my bad english.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5017
    Re: are kyocera 250ci toner compatibile with UTAX CDC-1725??
    Parts are the same but toner is not.
    • Larhal
      • 609
      The machines are the same as is the actual toner.
      Issue 1: The information on the chips are different and the cartridge will not be recognized by the machine.
      Issue 2: The keys/ key plates for both machine and cartridge are different . The cartridge will not fit.
      Issue 3: depending on your location the drive gear on the Kyocera cartridge will be different, This is the gear that engages with the machine to feed out toner.
      Other than that the toner will work.....
      Larhal
      Larhal
      If all else fails read the Service Manual!
      If that fails, meet me at the pub and we will discuss it.
      • mrbu
        thanks to all, Triumph Adler it's have the same problem??
        thanks
