CS 400ci Output options for copying grayed out.
  • Xferunit
    • 57
    [Misc] CS 400ci Output options for copying grayed out.
    I've seen this on a few Saturns. The output option for print, and fax are available to go to any tray, however, for copying only Tray A is available in the default output in the system menu. Has anyone seen this before? If so, what is the remedy? Thanks.
    • 23008
    Re: CS 400ci Output options for copying grayed out.
    Your finisher has been isolated because of an error. Print off the U000 Error log. That will tell you what to fix. Clear the error in U906, then fix the original cause for the isolation. =^..^=
    • darry1322
      • Oct 2010
      • 817
      Is Offset also set as a default? Tray A is the only tray available to Offset.
      • Xferunit
        • 57
        I believe this is the case, and that's probably the reason. To be clear, I can use all of the trays. Stapling, collation, it all works. Just on copying, the only available output option is Tray A.
          • 23008
          Nice catch darry. =^..^=
          • darry1322
            • Oct 2010
            • 817
            I've run across a couple of these situations lately.
            • tonerleak
              • Mar 2012
              • 67
              Had the same type of issue on a Taskalfa 4500i with a mailbox option,output options were greyed out until offset was enabled.
