Almost Blank Copies on Kyocera 3650W after replacing drum, or removing Developer
  • timlapine@gmail.com
    • Apr 2013
    • 3
    [CQ] Almost Blank Copies on Kyocera 3650W after replacing drum, or removing Developer
    A Real Eye Opener.
    This machine appears to have two screws that hold the Developer unit in when shipped. They are removed so two cams can push the developer unit to the drum.
    If you take this machine apart and spend a few hours doing a full PM, be careful not to put screws in these holes.
    It looks like they are needed but the cams will hold the developer unit in place when you reinstall the front panel.
    If you put the screws in it will hold the developer unit from the drum resulting in a small 10% copy with most of copy blank on right side.
