Kyocera KM 6030 Jam report question
  • Doug James
    • Jan 2012
    • 935
    On this report, what is difference between the "total" and the "count" columns. I have a machine in a school that has intermittent jams that I cannot duplicate. Needing a little help understanding the jam history. (Image attached)Kyocera 6030 Jam Report.PDF Thanks so much
  • CraiginAK
    • Jan 2013
    • 88
    Re: Kyocera KM 6030 Jam report question
    The total column is for total number jams for life of machine and is not resettable. The count column is resettable by you in mm903. Its good clear the counts after a jam service call so can see what's happening if get called back.
    • Doug James
      • Jan 2012
      • 935
      HUGE HELP, Thanks so much !!!
        • 23010
        That's about the only way to get useful information from that jam report. You don't get the date/time of jam occurrence, date/time of jam clear, sequence, paper source ... it's just a list of every jam that happened since the last clear. =^..^=
