JAM KYOCERA TASKALFA 400
  • ivanusicnm@gmail.com
    • Oct 2012
    • 22
    HEELO!!!!
    I have some trouble with taskalfa 400. It is offen paper jam in the fuser unit or exit unit. I replace exit unit and fuser but no results.
    Olso replaced the pick up unit. this paper jam hapened mostly in the morning. When I came to the customer, machine works normaly.
    i have some example.....
    any suggestion?????
    • 23010
    Re: JAM KYOCERA TASKALFA 400
    jam code? =^..^=
      • Oct 2012
      • 22
      jam code? =^..^=
      it is no code because paper go out but crushed.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
          • 23010
          Just to clarify: So it doesn't jam?
          I don't think I can help you, if you cannot make up your mind on so basic an issue. =^..^=
          • NeoMatrix
            Senior Tech.
            • 3513
            Is this a moisture problem first thing in the morning ?
            Does the copier have heaters fitted to the paper trays ?.
