TA520i LCT
  • blackdog
    • Jun 2012
    • 211
    TA520i LCT
    Blackcat, just talked to customer in regards to that issue feeding via DP.
    Any quantity input and unit will ask for paper in MP Tray.
    Here's the kicker, customer complaining that LCT not functioning, no error codes.
    I'm thinking this is indirectly related to MP Tray, LCT sensors, lift motor?
    Your expertise is needed here.
    • 23010
    Re: TA520i LCT
    First thing to do is to print off the U000 Event Log to see what error occurred. =^..^=
    • blackdog
      • Jun 2012
      • 211
      Re: TA520i LCT
      That's affirmative.
      Question; I have a TA250ci parts machine no LCT option, any feed parts interchangeable with LCT?
        • 23010
        Re: TA520i LCT
        Originally posted by blackdog
        That's affirmative.
        PF-760(B)? Nothing in common with KM-250ci, not even rollers.
        With only very slight mechanical differences it is the same LCT used on Falcon I and II (PF-75), Falcon III and VoyagerE (PF-750), Falcon IV (PF-760(B)) =^..^=
        • blackdog
          • Jun 2012
          • 211
          Re: TA520i LCT
          Figured as much. But customer mentioned it (LCT) wasn't lifting. Maybe wishful thinking, but a slipping clutch
          may need a little squirt of contact cleaner?
            • 23010
            Re: TA520i LCT
            I don't just make random guesses without the error code.
            It's probably the muffler bearing. =^..^=
            • blackdog
              • Jun 2012
              • 211
              Re: TA520i LCT
              Ain't nothing wrong that (guess), a correct one has changed a lot of peoples lives for the better.
              I'll post my findings tomorrow after a good look at the beast.
              Thanks again
              • copymech
                • Sep 2011
                • 196
                Re: TA520i LCT
                906?
                • blackdog
                  • Jun 2012
                  • 211
                  Re: TA520i LCT
                  Originally posted by copymech
                  906?
                  This is highly probable...
                  • blackdog
                    • Jun 2012
                    • 211
                    Re: TA520i LCT
                    Well it sure wasn't the muffler bearing and I also checked the left handed devise for burrrrrrs. Nada, whada dadah.
                    So it looks like virus has moved to trays 1 & 2. I disconnected tray 3 (lct) altogether and now asking for supplies in 1& 2 even though all is positive, settings etc.
                    I can't even access service mode.
                    Power off and on, drum refresh appears briefly and then displays add paper to both remaining trays??????????
                      • 23010
                      Re: TA520i LCT
                      Maybe you've got a shorted lift motor (which usually fries the motor control portion on the engine PWB).
                      Try this: Leave the PF-760(B) disconnected. Unplug the lift motors. If I'm right the machine should power up, access service mode, and feed from the MP tray. =^..^=
                      • blackdog
                        • Jun 2012
                        • 211
                        Re: TA520i LCT
                        Thanks for your super fast response, it's good for the psyche.
                        If you're right, would then the engine board be toast?
                        Right now we are in the midst of a snowstorm so I'll hang out here for awhile.
                          • 23010
                          Re: TA520i LCT
                          Not 100% sure, but certainly possible.
                          You can test the Engine PWB output for:
                          lift motor 1 LM1 at YC8 A17/A18
                          lift motor 2 LM2 at YC8 B7/B8
                          If the motor control circuitry is fried you won't get 24vdc.
                          • Tonerkiller
                            • Oct 2012
                            • 668
                            Re: TA520i LCT
                            Have you bent down and shimmed down the brackets for the lct? That is the whole problem.
                            • blackdog
                              • Jun 2012
                              • 211
                              Re: TA520i LCT
                              Alright I jumped into the old jeep, locked up the 44's and headed out.
                              Removed lift motor connectors, main LCT connector, powered up and the sucker fed legal (tray2) until empty, than same scenario, no lift on anything other than my jeep. Thought we had it for a moment.
                              Checked 24v, fluctuating but it's there.
                              You know this whole issue started with a jamming finisher (entrance sensor) than the issue with quantity feeding thru DP,
                              then LCT, then trays 1 & 2. I think it's time to take a shot in the dark without the ability to access service mode I'd bet on engine board, power supply or hard drive. But not in that order.
                              Tonerkiller I don't think that matters when LCT is no longer in circuit.
