kyocera km 2050 memory ram upgraded
  • gean
    • Feb 2014
    • 6
    [Error Code] kyocera km 2050 memory ram upgraded
    hello, any one can tell me how upgrade memory ram on kyocera km 2050, i'm no sure if i have to run U021 after put the new memory?
    thank you.
  • JustManuals
    • Jan 2006
    • 9838
    Re: kyocera km 2050 memory ram upgraded
    http://www.justmanuals.com
    Paul@justmanuals.com
    • gean
      • Feb 2014
      • 6
      THANK YOU PAUL i HAVE THE SERVICE MANUAL BUT THE MANUAL NO SAID NOTHING ABOUT HOW UPGRADE THE MEMORY RAM.
        • 23010
        Negative on that. Just print the printer status page to see if the optional memory shows "installed".
        • gean
          • Feb 2014
          • 6
          NO, THE STATUS PAGE SAY MEMORY: 64 + 0 MB
          ANY IDEA blackcat4866 , THANK YOU
            • 23010
            Ok. So the first question is: Which DIMM memory are you trying to upgrade? multiple choice: copier or printer
            Before the DIMM memory can be upgraded the MFP must be turned off and unplugged.
            The copier can be upgraded from, 64MB in port YS1, by removing the 64MB DIMM and installing up to two 128MB DIMMS in ports YS1 and YS2 on the main PWB.
            The printer can be upgraded from 64MB built-in to 320MB, by adding up to 256MB DIMM in port YC2 of the printer card. Additionally a MicroDrive can be installed in the CF port of the print card.
            This information is scattered around, here and there, but mostly in the release bulletin #1. =^..^=
            • gean
              • Feb 2014
              • 6
              Thank you blackcat I'm trying to install a printer memory card. You said it was only one slot for the printer and I saw 3 slots 2 bigg with 1 card 64mb and the third is small and empty, I'm starting to think I have the wrong memory because it's for the biggest slot which I understand now is for the copier because you said the copier memory has one 64mb and the printer has 64mb whitout any card . Do you know what I need to buy to increase the printer memory.thank you
