There where some power outages around my area and now I have a 3050ci that randomly shuts off or loses power. I think it got a surge because one second it's fine and the next second the screen goes blank and the all the LEDs on the control panel go out but there are still fans running in the back. It happens randomly but almost always within 15 minutes of it being powered on and the only way to get it to turn back on is to turn the main power switch off and on. Also, when it is on it won't connect to the network. No lights come on at the port and I can't ping it or anything. As per Kyocera's instructions, I've already swapped the LVPS and that didn't change anything and tomorrow when the main PWB comes in I'm going to replace that. Does a faulty main PWB sound like the most logical culprit? Also, when you change the main PWB you have to switch over the EEPROM and the code DIMM from the old one to the new one? Any chances of those having issues from the possible surge? This will be my first time having to replace the main PWB on a Copystar so any advice is appreciated. Thanks in advance!
CS 3050ci shutting off randomly
Re: CS 3050ci shutting off randomly
Have you printed out the event log? There may be a code to help explain things on the log. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Did you checked to see if this copier is on a dedicated circuit that is supplying the correct voltage ?
If it is not dedicated, what else is on this circuit ?
The event log will certainly help."The Serenity Prayer" . . .
God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .Comment
Just because you're not paranoid doesn't mean they're not out to get you.
O.o
WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
Good to hear you got that problem fixed.......
Thanks for sharing that FIX
Now , if anyone else has a similar problem, they know where to look ..........."The Serenity Prayer" . . .
