KM 3050 PROGRAM LOADING
  • quitech
    • 82
    Dear friends,
    Greeting to you all, please friends, this problem of program loading for km 3050/4050/5050 is driving me crazy here in my country,i try to update the firmware but the machine is not responding, the memory indicator will not indicate, i change the hard disk and still the same.in fact i don't know what to do again please i need help if any of you have come across the problem.no error code display, only PROGRAM LOADING will display on display panel. help me out please.
    thank
    quitech
    • 23009
    Re: KM 3050 PROGRAM LOADING
    I think I'd try the Code DIMM next, then try again to reload firmware. It's the memory that holds the machines firmware on the main PWB. Code DIMM: 302GR94201 =^..^=
    • JR2ALTA
      • Feb 2010
      • 2033
      Before you do anything else, please clarify how you updated firmware. When the machine is unresponsive, you need to update firmware via CF Card not USB.
      • Tonerkiller
        • Oct 2012
        • 668
        Does it have the new style dimms? If not I would start there.
        • quitech
          • 82
          Dear friends,
          Thanks a lot, i try the method of cf card and three machine respond and accept the firmware while two did not respond.i thank all of you may God bless you all
          quiteh
          • feroz
            Originally posted by quitech
            Dear friends,
            thank
            quitech
            sir in this model after programme loding any error shows u like cfb 31. one small ram in display problem.
            • habik
              • 2013
              I'll bet you have changed the touch screen and misplaced connector on display PWB. There is 2x 5 pin CN1 and CN8 if my memory serves me well and only 1 5pin cable. Or was it 4pin? Sorry don't remember but this is usually the case when machine worked and then it came with Program loading.
              Option 2: faulty DIMM
              Sent from my iDon't believe in marketing device using Tapatalk
              Firmwares HERE
                • 23009
                That's accompanied by a CFB31, habik. But he may not have noticed. And it's the (5) pin operation panel harness connector to YC1. Leave YC9 empty.
                You were close. =^..^=
                • habik
                  • 2013
                  Well I was guessing from top of my head on the YC9 Thanks for correction. However I must say, that if you can't get the machine to load, you can't print anything to check on Service report. I had it in the workshop a while ago and I do remember that it did not give any code what so ever.
                  Either way cheers for correction!
                  Firmwares HERE
                    • 23009
                    The CFB31 appears on the machine display after about 10 minutes of Program Loading. No need to get to the event log. =^..^=
                    • habik
                      • 2013
                      Time is money
                      Firmwares HERE
                      • aborad
                        • Aug 2011
                        • 61
                        Check cables which is connected to Control Penal to Main board. i mean continuity.
                        • techandtrader
                          • Jun 2016
                          • 335
                          What is a source for the Firmware? Kyocera Website? I dont work on these. Also never replaced a drive before? Plug and play?
                          I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
