I have a intermittent problem with the DP on these machines. If you put pages in the dp and press copy the machine starts to scan from the flatbed. I have updated firmware, changed paper detect actuator, pcb in dp, paper detect sensor.....still intermittent problems....Any ideas?
Kyocera FS1135MFP- Not seeing document in DP
Re: Kyocera FS1135MFP- Not seeing document in DP
Check all the DP door interlocks and DP closed switches/sensors. Most likely one of them is being made only intermittently. =^..^=Last edited by blackcat4866; 03-05-2014, 05:48 PM.If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
I ran into this with a customer who would alternate between DP and platen copies. After a platen copy, she would place the original in the DP, lift it to remove the original from the glass, and then press start before the DP was completely closed. Unless the DP is recognized as "closed", it would just copy off the glass.Comment
When the top of the scanner was taken off to clean the optics the connectors could have been pulled. Reseat all connectors from the feeder, top cover and main board. I have seen this before.Comment
