I have a KM-C4035 that has a CQ issue internal prints are fine and off the glass is fine the issue is when using the ADF I get intermittent CQ problems sometimes a blank copy sometimes a washed out copy or a copy with heavy background. ....any suggestions
Kyocera KM - 4035
Tags: None
Re: Kyocera KM - 4035
I'd lean toward the DP not sitting evenly on top of the machine. We used to have a tech that would try to adjust for original skew by adjusting the DP hinges. If the height is not even on 3 of the 4 corners, and the DP sitting squarely over the slit glass you can get some very strange copy quality. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
