KM TA 250Ci with C6030 Thermal fuse Open
  • Gar the pilot
    [Error Code] KM TA 250Ci with C6030 Thermal fuse Open
    Our Clients Fuser had a jam that got on the belt and under the Thermistor. It caused a C6030 code and took out the thermal device that goes through the middle of the Heat belt. I get an Open when going front to rear on the white Lamp connector. Ideas other than R+R unit ( I am installing a Loaner unit ) as there is no brake down. Anybody figure a fix for this yet? In the old days we could put the thermal ( clicks off ) device in the freezer to reset, hasa anyone tried this?
    Gar the Pilot
    Fly'n weather is coming to a sky near you.
    • 23008
    Re: KM TA 250Ci with C6030 Thermal fuse Open
    It's wax. It doesn't work. You're best hope is to scavenge the part you need from a recovered unit damaged in some other way. They are definitely not the easiest fuser to work on, but manageable. =^..^=
