300ci chirping in paper conveying section
  • BHRLC
    • Nov 2013
    • 77
    In attached PDF, noise is coming from motor or gear (#69/79 in pic)
    I have lubed up the gear/shaft/back of motor where clip goes with
    high-quality PTFE stuff and it went away for a bit but is back now but mostly when
    the machine has warmed up and put out several prints or so.
    It's literally a chirping that the customer really doesn't want to hear
    as the machine is in a small office.
    I isolated the noise by slightly pressing on the back of the motor to change
    rpm's and found it that way.
    Obviously since it's under MC and to save costs, should I change the gear, housing or motor?
    • 22973
    Re: 300ci chirping in paper conveying section
    I conversed with a tech recently who silenced a squeak in this unit by cleaning and lubricating the impregnated bronze bushings. I think I'd try that first. =^..^=
    • BHRLC
      • Nov 2013
      • 77
      I think I will try that.
      • BHRLC
        • Nov 2013
        • 77
        It seems to have stayed away after the lube soaked for a few days
        Thank God for Teflon!
        • Eric1968
          • 2458
          I had also this kind of sound on a TA300ci, I cleaned/lubricated the white plastic rollers in the lower side cover.
