TA3050ci
  • spacedust
    spamanamamammmmm
    • 47
    TA3050ci
    HI AL
    WE HAVE AN ERROR OF c6900 WHICH POPS UP FROM TIME TO TIME.
    LATEST FIRMWARE INSTALLED AND FRONT FUSER FAN FITTED.
    CHECKED RELEVENT CONECTOR ON ENGINE PWB (YC26).
    BUT ALL LOOKS FINE ,ITSONLY AROUND A YEAR OLD WITH AVERAGE MILES ON IT.
    ANY BODY HAD THIS BEFORE PLEASE ?
    REGARDS
    SPACEDUST
    • 22999
    Re: TA3050ci
    The C6900 refers to the fuser edge fan motor 1 (FUEFM1), or fuser edge fan motor 2 (FUEFM2), not the fuser front fan motor (FUFFM).
    Did you change the fuser front fan motor (FUFFM): Figure 20 Item 11 or A02? 302K994350 or 302K994090
    Did you change the fuser edge fan motor 1 (FUEFM1), fuser edge fan motor 2 (FUEFM2): Figure 20 Item 29? quantity (2) 302FZ94420
    I only read one fan, and the wrong one. =^..^=
    • spacedust
      spamanamamammmmm
      • 47
      Re: TA3050ci
      1702LK0UN2
      Hi blackcat
      thankyou for the reply.
      i have been looking into this a little more over the weekend and it seems i have two poss issues here.
      firstly i think the original tech has poss fitted the wrong fuser to this machine (45/55 cpm rather than 35cpm)
      plus the tech who ordered the fan before i was dragged into the complaint may have ordered the wrong fan up afterwards.
      but to be fair the fans in the uk are not listed seperatly in the parts book as they come with the fuser i think and the fuser can only be ordered as a whole unit.
      but the front fan is listed as a fuser front fan ?
      odd......
      in the servive book the other fans are pointed out, just not in the parts book....?!?
      so i am ordering a fuser.
      will let you know.
      thankyou again.
        • 22999
        Re: TA3050ci
        1702LK0UN2
        Just to confirm: This looks like a 120V fuser, like the ones we use in the US. I thought you used 220v fusers in the UK. You would have seen smoke if the wrong voltage fuser had been installed.
        Am I wrong? =^..^=
