FS-4200DN blank printing
  • shamgar1981
    • May 2012
    • 34
    #16
    Re: FS-4200DN blank printing
    I had one today with 2M prints, and an "Add Toner" indication that wouldn't clear. The developing and registration clutches are rusting badly. The problem I'm having is the bushings are ovalled out. There is no separate part number for the bushings and they're not like anything I've seen before. Does anybody know a part number to sub? =^..^=
    [ATTACH=CONFIG]34661[/ATTACH]
    EDIT: To my surprise, in the "bushing collection" I found 24 bushings of the appropriate size and dimension. 8 of delrin and 16 oil impregnated bronze. What dimensions, you ask?:
    6mm ID
    9mm OD
    two opposing flats measuring 8mm across the flats
    3mm or greater into the frames
    All set then Black cat? I was going to offer you a few off a parts printer I have, only about 45 min north of you.
      • 23010
      #17
      Yes, I found some oil impregnated bushings that will fit nicely. It's nice to know that there's another tech so geographically close. =^..^=
      • luddite
        • Dec 2010
        • 5
        #18
        Hi All just to add to the blank page ouput issues, i have had the same fault the cause was HV Pwb.
