Kyocera km5050 Touch screen problem
  • Crni
    • Mar 2014
    • 54
    [Misc] Kyocera km5050 Touch screen problem
    Hi all,
    Today while I was working on the machine touch screen just stopped responding. I restarted the machine with power off/on.
    After that I got beeping sound like I was pressing the touch screen (which I was not ). Touch screen still not responding on my touch.
    I went into calibration U201 and pressed Start. Got my calibration crosses and one of them was not responding on my touch, but automatically activated itself .
    It didn't allow Initializing the touch panel .
    I disassembled Operation panel and only thing that looked suspicious was the link on Touch screen which was folded in two places 90 degrees . (image below ) shows the places where it is folded.
    I fear the links have been cut. I don't know how this has happened .
    How can I test the touch screen ?
    • 23010
    Re: Kyocera km5050 Touch screen problem
    Have you tried the search function? I know of at least five threads on this topic:
    What part numbers?:
    http://www.copytechnet.com/forums/sh...l=1#post311379
    Why does it fail?:
    http://www.copytechnet.com/forums/sh...l=1#post291835
    • terrells
      They go bad and need to be replaced. We have had to replace them on multiple machines.
      • Crni
        • Mar 2014
        • 54
        What part numbers?:
        Why does it fail?:
        Thx for links Blackcat. I was searching with "Touch screen" :/ English is not my native language .
        Well I hope I can repair my ribbon link cos those things cost 100$ in US and I think they will cost way more here in Croatia because of small market :/
        • Crni
          • Mar 2014
          • 54
          terrells can you tell me what was wrong with your touch panels? Did they get the ribbon damaged or?
          • CraiginAK
            • Jan 2013
            • 88
            The ribbons don't go bad its the glue that holds the ribbon to touch screen that fails. A few guys have actually fixed these believe it or not with heating area with hair curling iron. I have done it also few times doesn't always work but sometimes. To test them you can ohm between the contacts on the ribbon there are three readings should be able get and if not it's bad. I have procedure some where on fixing if want me email it to you. Here is link to thread where he describes how to fix and readings for testing the panels. http://dnet-km.com/eve/forums/a/tpc/...467#3203947467
            • Hansoon
              • Sep 2007
              • 3391
              Densi sells them:
              Part # MATP0001 Kyocera-Mita KM-3050, KM-4050, KM-5050 (I) *
              Copystar CS-3050, CS-4050, CS-5050
              Hans
              • Crni
                • Mar 2014
                • 54
                Strange thing with this panel.
                I fixed the ribbon link and when i do U201 calibration it beeps like it has pressure on it somewhere :/
                Contact on the glass are still ok (as I can see)
                • Crni
                  • Mar 2014
                  • 54
                  First the left and middle didnt work at all then I loosen the screws and now middle and right cross calibrate ok but the left one is activating itself .
                    • 23010
                    You didn't fix it. Don't be cheap. Buy the parts. =^..^=
                    • Crni
                      • Mar 2014
                      • 54
                      Problem is that I am not 100% sure it is only the touch pad part :/
                      I will buy the part from Hans. He was very nice and professional, answered me in few hours time
                      Blackcat do links have constant ohms when you test them?
                        • 23010
                        They're supposed to. I have not had much success with this "repair method" discussed. It's almost certainly a return call. =^..^=
                        • Crni
                          • Mar 2014
                          • 54
                          I just need it to hold few days until new part comes .
                          Things fail you when you need them the most :/ (I sound like a girlfriend complaining about her man haha )
                          • kkendric
                            • 301
                            Do it Right, Replace the Touch Screen and be done with it, Try some common sense. These used to be on back order because of the failure rate.
                            • Crni
                              • Mar 2014
                              • 54
                              I will buy the new part from Hansoon.
                              He will send me by mail. Depending of the postage service it can take from 3 to 10 working days to get here.
                              So I wan't to get my machine operational at least until the part comes and also to know what to do if it happens again
                              I got this machine second hand and I am learning all the stuff about it.
                              Any other tips about keeping it alive are welcome
                              Thx guys
