KM-5050
  • BSGINC
    • Jan 2012
    • 19
    [Misc] KM-5050
    LCT keeps dropping off the grid, 906 it comes back for 3-5 days then disappears again. any thoughts? Using TVSSR units as well. Then the driver disappears and the pc shows this messageKyocera Error.jpg
    • 23010
    Re: KM-5050
    This was happening quite often on certain versions of the print driver. Essentially the print driver does something called "Silent Configuration", which means that it checks what accessories are available. If the machine does not respond for any reason, then you've lost your accessories from the driver configuration. You have two choices, depending on which version of the driver you're running:
    1) Disable "Silent Configuration" in the print driver > Properties > Device Settings. Then run Configuration once or manually configure.
    2) Disable SNMP.
    • BSGINC
      • Jan 2012
      • 19
      Re: KM-5050
      2) Disable SNMP.
      I will check those things today Thanks!
      • Kidaver
        Ghoulscout
        • Apr 2011
        • 912
        Re: KM-5050
        As to why your LCT keeps disabling itself I would check the lift motor on the right side and make sure the shaft hasn't warped causing the coupler to not spring forward...if it's sticking then replace it...very common on the LCTs...
        "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
        • BSGINC
          • Jan 2012
          • 19
          Re: KM-5050
          Yes we refurbed the LCT and took care of that ... Thanks
