Lost a shaft pin? DIY!
  • BHRLC
    • Nov 2013
    • 77
    Working on a 2050's DP, when, you guessed it.
    I had a nozzle tube from a can of compressed air in my toolbox, luckily.
    Cut it to size, works like a charm!
    BTW, thanks Kyo for making those things so impossibly small and easy to lose.
  • darry1322
    • Oct 2010
    • 817
    Re: Lost a shaft pin? DIY!
    I've clipped a piece from a large size paper clip before. They seem to work and are usually handy.
    • BHRLC
      • Nov 2013
      • 77
      That must have been a really large paperclip
      • darry1322
        • Oct 2010
        • 817
        It was a little small on the diameter, but close enough.
        • habik
          • 2013
          I tend to disassemble old km6339 finishers and keeping all solenoids pins shaft pins C-clips brass bushings and yes big paperclips do the job just fine!
          Sent from my iDon't believe in marketing device using Tapatalk
          Firmwares HERE
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            I love McGuyverism!!!!!!!!!!!!!!!! Way to go guys!!!!!!!!!!!!!!
            Mystic Crystal Revelations
            • CCS
              • 266
              In a bind, I have clipped large paper clip pieces for use as well, I use 2 pieces sometime to take up some slack.
                • 23010
                Nice MacGuyver!
                Throw a metal coat hanger into your toolcase. You can cut durable pins of any length you like from that. =^..^=
                • darry1322
                  • Oct 2010
                  • 817
                  Nice MacGuyver!
                  Good idea!
                  • ZOOTECH
                    Senior member of CRS
                    • 3375
                    Nice MacGuyver!
                    I carry a few different gauges of finishing nails to cut to length - you do need a good and heavy duty wire cutter.
                    • Zackuth
                      • Aug 2009
                      • 448
                      Whenever I have a part I throw away, I always tear it down to get pins, clips, screws, etc. to carry around. I have two small hobby boxes that are full of the things. Saved me more than once.
                      If at first you don't succeed, redefine success
                        • 23010
                        A pair of regular pliers will cut coat hanger with a little effort. The friction wheel in the dremel will cut anything, as far as I'm concerned.
                        My Kershaw multitool is the first thing I reach for. With hardened wire all you need to do is crease it a little then work it back and forth to break it off.
                        Fence wire is a step bigger than coat hanger, but difficult to cut without fence pliers or dremel. =^..^=
