Kyocera FS - C5300 DN color position shift and failure to adjust the colour regist
  • kibbs
    • Apr 2013
    • 94
    [CQ] Kyocera FS - C5300 DN color position shift and failure to adjust the colour regist
    Dear all, Today i am facing the color registation problem in Kyocera Fs-C5300dn.. i get the bulletin from kyocera site.. SB Number: SB 2HN-014. I am follow the instruction and also the problem is same.. i don't know what to do.. for view i attached the sample status page and color registration with this page..please give the solution for me...
    i tried prescribe command also
    !K! KCFG"SVEG",208, 10;EXIT
    but not use
    thanks & Regards
    kibbs
  • kibbs
    • Apr 2013
    • 94
    Re: Kyocera FS - C5300 DN color position shift and failure to adjust the colour regis
    but not use
    thanks & Regards
    kibbs
    Today i am replace the Transfer and also problem remain same... any help..???? new firmware also tried.
    • stevena86
      • Oct 2012
      • 130
      It appears it's just the black that is off. Is the black drum/developer seated correctly?
      Do the color calibrations and see if you can calibrate the machine.
      • rashid120
        • Jun 2010
        • 76
        but not use
        thanks & Regards
        kibbs
        My friend,
        please try this firmware and let me know.
        Firmware upgrade (Main v.007.008 and Engine v.011.001)
        Registration problem was solved through this firmware. Gud luck
        Thanks and Regards.
        Rashid iqbal.
        • kibbs
          • Apr 2013
          • 94
          i noted its seated correctly in the machine.. i do color calibration problem looks same..
          • Zackuth
            • Aug 2009
            • 448
            You will have to do a color registration several times to bring this back into alignment. I had a similar machine that was as out of registration like your machine that it took 6 times before it was correct.
            If at first you don't succeed, redefine success
            • Tonerkiller
              • Oct 2012
              • 669
              I had one like that. I did the reg adj to the max about 20 times to get it right
              • jonbonse
                • Jun 2009
                • 737
                Hi all
                i have this in a FS-C5350 and have been told there's special firmware to fix...
                Has anyone got it?
                  Check your pms
                  • jonbonse
                    • Jun 2009
                    • 737
                    Originally posted by skynet
                    Check your pms
                    Hi
                    Do you have the bulletin on this?
                    • Has Been
                      • Nov 2012
                      • 48
                      Originally posted by jonbonse
                      Hi
                      Call the hotline and have them remote in and reset the printer.
