KM-1118 scan to folder
  • cmpelser
    • Jan 2008
    • 173
    Hi guys,
    I am new to the Kyocera.
    I`ve set up scanning (to folder - smb)
    Is there a way to bi-pass the entry of the username and password needed to scan?
    It takes too long for the customer to scan... pushing 100 buttons!!!
    They are still used to the gestetner that they had (mp161)
    Thanks!!!
  • aragul
    • Dec 2007
    • 128
    Not on this model. We don't even tell customers that it scans to SMB or FTP, only scan to e-mail.
    The only time I've seen it save a username and password is for network fax.
    • JSC
      Gimp
      • Dec 2006
      • 618
      Originally posted by cmpelser
      Hi guys,
      Thanks!!!
      I thought there was some special firmware you could get that got around this particular issue?
      Check with your local tech rep.
      The gene pool could use a little chlorine.
        • 30245
        smb
        add a user with admin rights
        name a password a
        scan folder on c drive and share
        or set it up to scan to email or twain with usb cable
        • frank.givskud
          • Jun 2008
          • 5
          there is a special firmware for this issue. I know the name of the file, but don't no where to download it. Firmware file: Local_S2GM2012E06001.zip
          • goggelkopf
            Hi,
            I do need this firmware too, but I can't find it anywhere.
            Does anybody have this file? It would be great!
            Thanks.
            • geisener
              i agree with bsm2 just set up a user name a with a password of a
              • aodtech
                • 194
                When setting up the destination folder which has to be shared in order to scan to it, Properties, Security (right next to Sharing) under Group or User Names Add EVERYBODY and click Allow for for everything. This way you can type anything (as long as it's something) for username and password and you'll be able to scan. To get the Security tab in XP Home, start Windows in Safe Mode and it'll be there.
