Kyocera 6030 C00500 Error after changing Feed Tires
  • Doug James
    • Jan 2012
    • 935
    I took the C1 deck out and changed the feed tires. Everything went smoothly and (all the wires plugged back in) when I put the Deck back min I started smelling smoke and the C00500 error wont clear. Not sure what I did but looks major... Any Help would really be GREAT !!!! Thanks So Much...
    • 23010
    Re: Kyocera 6030 C00500 Error after changing Feed Tires
    Originally posted by Doug James
    ... when I put the Deck back min I started smelling smoke and the C00500 error wont clear. Not sure what I did but looks major... Any Help would really be GREAT !!!! Thanks So Much...
    You're code was probably C0500 (Paper Deck Communication Error), and you probably fried the paper deck controller. Just hope it's not the engine PWB. It would have been a good idea to turn it Off beforehand. =^..^=
    • Doug James
      • Jan 2012
      • 935
      I turned it off, lol... I am having a heck of a time trying to figure out what I did. I guessed I pinched a wire in the C1 paper deck, but I can't find it... Thanks so much for your input... Took them another machine today to use, tomorrow am going to look for the PWB (engine or paper deck controller) with a burn mark and replace it...
