CS 3060 PM
  • copiman
    • Sep 2011
    • 861
    CS 3060 PM
    I wanted to make sure I am on the right page. I am going to install a PM kit (MK-671) and wanted to make sure I run the proper maintenance modes. I have researched the manual and see that I need to do the following:
    Drum unit U110
    Dev unit U157
    Fuser unit U167
    Feed unit U903
    Is there anything I'm missing?
  • MDR24
    • Apr 2013
    • 64
    Re: CS 3060 PM
    I'd also clear sim251 and make sure sim250 is set to 300,000. Or else you'll get a Time for Maintenance message before it's due.
    • copiman
      • Sep 2011
      • 861
      Re: CS 3060 PM
      Thanks. I will do those as well.
        • 23008
        Re: CS 3060 PM
        You'd better do U130 also, or your first 500 prints will be blank. =^..^=
        • copiman
          • Sep 2011
          • 861
          Re: CS 3060 PM
          Thanks blackcat4866. Will add that to my list. This is the first PM for me on Kyocera/Copystar. After installing the kit, is there a particular sequence in which run all the simulations listed in my original post and those that you and others have mentioned?
          • copymech
            • Sep 2011
            • 196
            Re: CS 3060 PM
            Inside the pm kit will be instructions listing the service modes needed.
              • 23008
              Re: CS 3060 PM
              U130, U251, then the rest doesn't matter. =^..^=
              • copiman
                • Sep 2011
                • 861
                Re: CS 3060 PM
                Thanks for the help. I am doing the PM tomorrow.
