KM 5050 secondary power button lights up, however,no lcd , and mfp will not cycle.
  • walterman
    • 196
    I have a km 5050 that will not cycle, no lcd display.. but the secondary power button will light up. I have checked the ac power at the wall, removed the nic, still have the same issue. Any ideas?
  • walterman
    • 196
    Re: KM 5050 secondary power button lights up, however,no lcd , and mfp will not cycle
    I have also checked all the fuses on the power supply for continuity and all fuses are good. I'm thinking mai board possibly.
    • kkendric
      • 301
      So you removed the main board, since this machine does not have a removable nic. You could be missing some voltages. The engine board should at least initialize.
        • 23010
        I'm thinking operation panel firmware. Start with a firmware re-load. =^..^=
        • walterman
          • 196
          kkendric, you are correct about the nic, it is my fault, I meant the fax board.
          • walterman
            • 196
            I installed a new power supply and the mfp came to ready, upon, completion of that I was able to install the firmware. Thanks for the responses.
            • kkendric
              • 301
              Missing voltages as I thought.
