Kyocera km2560 c9000
  • daveh12
    • Jul 2012
    • 157
    [Error Code] Kyocera km2560 c9000
    Hi all,
    Have a km2560 that shows an error c9000 intermittently, manual says to check connections between board and df which are fine and the wire harness is good too. Only other thing manual says is replace engine board. Now before going down that costly route has anyone had this problem before? Did you have to replace the engine board to fix it? This machine is still reasonably new with under 200k on it. Any suggestions really appreciated.
  • GESPAGE
    • May 2011
    • 40
    Re: Kyocera km2560 c9000
    Originally posted by daveh12
    Hi all,
    • GESPAGE
      • May 2011
      • 40
      Hi all,
      SB-3K5-0012-9119.pdfSB-3K5-0012-9119.pdf
        • 23008
        I've found that just metering out the pins does not tell you the whole story. I'd still replace the pigtail as my first attempt. =^..^=
        • daveh12
          • Jul 2012
          • 157
          Just to come back, replacing the "pigtail" seems to have done the trick. Thanks for the help.
