kyocera km-3050 machine jam 21
  • rana
    • May 2014
    • 19
    [Jamming] kyocera km-3050 machine jam 21
    hai friends, does any one know about kyocera km-3050 showing jam 21.this machine is my customer side please give me solution and actually when i am take the cassette 2 this jam 21 error come . but when iam take casette 1 its working fine.the problem taking copy in casette2 . i check pully paper feed sensor and that one working .please any one knows please give me solutionthanks & regardsrana....
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    Re: kyocera km-3050 machine jam 21
    change out the vertical conveying clutch.
    Idling colour developers are not healthy developers.
      • 22930
      I have a couple of choices for you:
      Misfeeds (Jam J21) misfeeds from tray #4, legal size. Tray for is incorrectly hard programmed to letter size paper. Go to System Settings > Original/Paper Setup [Next] > Cassette Setting [Next] > Paper Size [Change] > Auto > Inch > OK > Media Type [Change] > Plain > OK > Close x4.
      Misfeeds (Jam J21) misfeeds from tray #3, ledger size. (21.03.0C.01.03) Inadequate pressure on left side door idler rollers. Install two add'l pressure springs at lower vertical path idler rollers in left middle door.
      That didn't come out as concise as I would have liked. Each idler shaft has one pressure spring. Install one additional spring per shaft. That's two additional ... or a total of 4 springs (2BL06340). If you get crazy and install three springs per shaft, it's too much and jams even more. =^..^=
      • rana
        • May 2014
        • 19
        I have a couple of choices for you:Misfeeds (Jam J21) misfeeds from tray #4, legal size. Tray for is incorrectly hard programmed to letter size paper. Go to System Settings > Original/Paper Setup [Next] > Cassette Setting [Next] > Paper Size [Change] > Auto > Inch > OK > Media Type [Change] > Plain > OK > Close x4.Misfeeds (Jam J21) misfeeds from tray #3, ledger size. (21.03.0C.01.03) Inadequate pressure on left side door idler rollers. Install two add'l pressure springs at lower vertical path idler rollers in left middle door.That didn't come out as concise as I would have liked. Each idler shaft has one pressure spring. Install one additional spring per shaft. That's two additional ... or a total of 4 springs (2BL06340). If you get crazy and install three springs per shaft, it's too much and jams even more. =^..^=
        ya this way iam try but when iam taking the copy from casette2 sound coming trrrruuu..like that after jam21 coming and that sound same as gear sound where the missing point to note. thanks& RANA
        • rana
          • May 2014
          • 19
          thank you very much ya i got it same thing
          thanks & regards rana
            • 22930
            Did it work for you? =^..^=
            • rana
              • May 2014
              • 19
              ya i did machine will working good
              thank you very much
              • niyaskarimba
                • Sep 2014
                • 110
                Re: kyocera km-5050 machine jam 21
                thank you very much
                Dear All,
                We are also getting the jam Code 21 while only copying or printing from bypass A3 size.
                A3 is woriking fine from cassettes and alos A4 is working fine from the bypass.
                Kindly suggest possible solution.
                Thanks in advancve
                Thanks & Regards,
                Niyas
                AST Group of companies
