Taskalfa Scan Issue
  • Houndquake
    Taskalfa Scan Issue
    Please someone tell me what I am missing. I have setup the smtp server settings, but when I try to scan to email, I enter the destination and hit start but the machine just beeps and says to hit start to send.
    Any ideas?
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Re: Taskalfa Scan Issue
    Which model of Taskalfa? as the older models have a bit different Command Center than the new ones?
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • Houndquake
      Taskalfa 205c
      • Kidaver
        Ghoulscout
        • Apr 2011
        • 912
        So you enter a destination and on screen you should see Ready to Send and there is no green light on the start button and if you do press start it doesn't even scan the document or try to send or give a send error code?
        • Houndquake
          its actually a 255c and I have discovered that I cant send anything from the send screen. Not a scan to email, scan to file, or even a fax. It just beeps. Any ideas?
          • Houndquake
            No error or anything, it says press start to send. You press start and it just beeps. It never pulls the document through the adf or scans it off the glass. If you dont have a doc loaded on the glass or in the adf it asks you to set a size and then just beeps after you do that.
            • Kidaver
              Ghoulscout
              • Apr 2011
              • 912
              Hmmm...that is an odd sounding issue...I'd start by pulling the fax and loading firmware and see if you can scan to file/email, re install fax, reload firmware, and then go from there...
              • rana
                • May 2014
                • 19
                i also faced this problem but i check the machine date and time .may be the machine date and time wrong .you check the date and time
                any way all the best
                • tmaged
                  Owner/Service Manager
                  • 1900
                  We have one doing this after changing the main board for black copies. The date & time are in there. Anyone figure it out ?
                  Hope that helps !
                  -Tony
                  www.dtios.com
                  Become a fan on Facebook
                  • blackandwhite
                    • Aug 2012
                    • 67
                    format HDD and reload the firmware... may it will help this issue.....
                    • tmaged
                      • 1900
                      Updating the firmware fixed our issue. It didn't get done when the board was replaced & I'm guessing they had different firmware versions.
                      Hope that helps !
                      -Tony
                      www.dtios.com
                      • Venom
                        Technical/IT Support
                        • Nov 2009
                        • 765
                        I had a ta 300i and firmware fixed same issue.
                        IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                        • stevena86
                          • Oct 2012
                          • 130
                          What have we learned?
                          When in doubt; firmware!
                          • Kidaver
                            Ghoulscout
                            • Apr 2011
                            • 912
                            I do remember an issue with the bad main pwb copying the black pages that with one level of FW it would still let you print and receive faxes but if you updated it you got a service code and couldn't do anything with it at all until you replaced the main pwb so I wouldn't be surprised if it was a firmware issue....
                            Edit: Now that I think aobut it I do recall that if you did replace the main pwb for the black page issue and did not update the FW on it you couldn't send/fax at all..so yeah....update the firmware..
