KYOCERA KM-3050 casette2 failure
  • rana
    • May 2014
    • 19
    hai friends, i have one kyocera km-3050 macine having casette2 failure problem and i check that lift motor i swap and also still same error showing where is the problem i didn't find pls tell me the solutions of this thread any one knows tell methanks & RANA
  • tcook
    • Apr 2013
    • 37
    Re: KYOCERA KM-3050 casette2 failure
    Engine Board.
    • Eric1968
      • 2458
      Did you perform U906 (Reset Disable Function) after the replacement?
      • Tonerkiller
        • Oct 2012
        • 668
        Replace the eng. board and lift motor as a set. search this forum. We have gone down this road before.
          • 23008
          I'm with Tonerkiller. It's a shorting lift motor that takes out the control circuitry on the engine board. To be safe, replace both lift motors with the engine board. Do you really want to take the chance? And you will have to clear the error in U906.
