Kyocera FS4020DN, how to......
  • Hansoon
    • Sep 2007
    • 3374
    ....replace the right hand black bushing #302F924190 of the transfer roller?
    There is a white plastic lever on top of it which I cannot remove easily. It seems that I have to take off the white part to replace the bushing but how?
    The manuals are not giving any clue.
    Hans
  • Hansoon
    • Sep 2007
    • 3374
    Re: Kyocera FS4020DN, how to......
    *mumble* *cough*
    Hans
      • 22999
      Sorry Hans, I haven't had the pleasure. =^..^=
      • Hansoon
        • Sep 2007
        • 3374
        Guys, nobody, really??
        Hans
        • Hansoon
          • Sep 2007
          • 3374
          Found it. Brought the machine into the workshop and with good light and a mirror I discovered that there is a latch molded into the black plastic frame which keeps the white lever from sliding to the right.
          Phew....
          Hans
          • HenryT2
            • 962
            Hans
            Try this ........
            Remove DV, DK, etc, The cam is just snapped into place; use a flat tip screwdriver as a lever and push the cam to the right .
            This should give you enough room to replace the broken bushing .
            ( You may have to remove the Duplex unit and Engine board to get to the clips on the bottom of the bushing; sometimes these bushings will just pop out .)
            Then just snap the cam back into position.
            GOOD LUCK !!!!!
            The other way is to remove the entire right side frame , then the cam , then you can EASILY ( HA HA HA ) replace the bushing .
            Hope this helps .......
            "The Serenity Prayer" . . .
            God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
            • Kyo fan
              • Dec 2013
              • 368
              Oh man i remember this one. After an hour of sweating i butchered the right side just to have a peak thru a tiny hole which showed me the latch at the bottom side of the white plastic piece. Nowadays i just use two smaller flat screwdrivers, one to press the latch under and other to slide it to the right, takes like 5 seconds.
