Kyocera KM 6030 C0220 Error code
  • Doug James
    • Jan 2012
    • 935
    [Error Code] Kyocera KM 6030 C0220 Error code
    I have been fighting this intermittent error for about a year now. It is a communication error between the engine pwb and the scan pwb. I have checked the connections in the book. Is the only way i am going to fix this problem is change the boards. Anyone have any work-arounds or any suggestions ? Thanks so much for any help...
    • 22999
    Re: Kyocera KM 6030 C0220 Error code
    It's not anything I've seen. Do you have a donor machine to swap boards with? Have you set up the power quality analyzer yet? =^..^=
    • Doug James
      • Jan 2012
      • 935
      I wish I had boards to swap... I have wondered about the power since I had another machine their with a power issue. I actually rolled (that machine) around the building plugging it in to different circuits. Ended up defective power supply.... A little history... This machine came out of storage after 4 years and after I put maintenance kits on it etc... the teachers started running about 50K a month on it for about 7 months so far. The error code was always popping up but until recently the code won't go away... (Basically, turning the machine off and on would clear code)
      • BSGINC
        • Jan 2012
        • 19
        I had this about a year ago on a KM 5050, the SCSI connector had tarnished connectors. Sprayed them down with contact cleaner then silicone spray took care of the problem and haven't had it since. The silicone will keep out the moisture and still conduct fine. Hope it helps.
