KM 4050 CASSETTE ERROR
  • quitech
    • 82
    Hi friends,
    Good day to you all, please i am facing serious problem for kyocera km 4050. The cassette 1&2 are not picking paper while the bypass i picking fine.
    After closing the cassette,the machine will display this message.
    ERROR OCCURRED AT CASSETTE 2 OR 1
    OPEN CASSETTE 2 OR 1 TO CHECK AND REMOVE PAPER FROM INSIDE THE MACHINE. This is what the machine usually display. i check inside the machine no paper was found, i used u906 and u021 reset and initialize no good result,please friends any idea will be appreciate
    Thank,quitech
    • 23009
    Re: KM 4050 CASSETTE ERROR
    Naturally, you should start by checking to see if there is any paper behind the tray, blocking the lift drive coupler. If you print an event log, what error messages are listed?
    You may have a shorted lift motor, and the shorted lift motor may have damaged the motor driver circuitry on the engine PWB. The way to clear this up in one visit is to order two lift motors and the engine PWB.
    If you order just the engine PWB, the shorted motor will again damage your new board. If you order one lift motor you have a 50/50 chance of guessing the correct one. =^..^=
    • Crni
      • Mar 2014
      • 54
      Do you remember what was the last thing you did before error started showing?
      Did you check paper feed motors in Maintnance mode? I guess you have the same maintnance modes as my km5050 so try U030 also U031 "Checking switches for paper conveying"
      I had same error as you few times, and I didn't saw the paper. Found the paper crumpled behind middle section of the left cover (i think it is duplex unit)
      Hope it helps
      • Barış KURT
        • Jul 2010
        • 72
        check "lift motor"
        Black is Kyocera , Color is Gestetner.
