keep getting a C2100 code on FS c2126
+ More Options
Posts
  • loubsg
    • Apr 2013
    • 6
    I keep getting a C2100 code after the machine runs a few color copies. History of Machine: this machine was shipped upside down from UPS (great job guys). I have cleaned out every inch of this machine. I have replaced a broken transfer unit. I have determined that this machine has not had bulletin #2 parts replaced (toner supply issue). ratchet shutter, holder joint, Cam toner supply, lever interlock, case spacer and parts waste toner assy (old). Has anyone run into this problem. I have determined the devo drive unit works just fine by hand rotation of motor, so does the drum drive (neither have been removed).
    Any Ideas?
  • DWise
    • 895
    Re: keep getting a C2100 code on FS c2126
    Any Ideas?
    Was the Transfer Unit broken due to shipping? If so, you should have filed a claim on UPS.
    Have you checked out the Developer unit?
    Do for one what you wished you could do for everyone. - Andy Stanley
