faded print / gray scale adjustment
  • irishtrash
    • Aug 2025
    I have a TACKalfa 250ci which has faded black print, I have done a dev refresh and this helped a little but when I print off a pattern sheet to do a grey scale adjustment and try to scan it, it tells me to check original and will not make allow me to do anything else any ideas what i can do or a work around?
  • Tonerkiller
    • Oct 2012
    • 668
    Re: faded print / gray scale adjustment
    With the info given. I would replace the dev.
    • Zackuth
      • Aug 2009
      • 448
      I agree with tonerkiller. The dev units (as well as drum units) for this series are not any good, about 100k I wait for them to fail. Occasionally you'll get a lemon that will last the whole 300k, but it's rare.
      If at first you don't succeed, redefine success
      • jmaister
        certified scrub
        • Aug 2010
        • 755
        if its faded as in bold fonts dont have complete fill.
        the dev is shot, replace it.
        Kyocera should sell these drums and K devs on bulk prices. This particular series is like owning German cars.
        Idling colour developers are not healthy developers.
        • Fusion
          • Feb 2013
          • 5
          I'm having this issue.....replaced iu's ,numerous developers(Works a couple hundred pages,then bombs),updated firmware.Does this machine even print a solid black? or should i get my client to lower ther standard alittle(Actually alot).
