CS 420i "On the glass" margin problem
  • Xferunit
    • 57
    [Misc] CS 420i "On the glass" margin problem
    Enclosed is what happens when you make a blank copy...The same will happen if you copy say a check, or a business card. There's that diagonal black line, like the scanner isn't straight. If you have a letter sized original on the glass, it copies perfectly. Any ideas as to what the issue could be? Anyone seen this before? I slid the scanner lamp back and forth several times and it seemed to move in unison, and with ease. 1.jpg
  • Luther
    • May 2006
    • 682
    Re: CS 420i "On the glass" margin problem
    looks like the pad on the document feeder isnt sitting straight or the feeder is crooked and light is escaping
      • 23010
      Originally posted by Luther
      looks like the pad on the document feeder isn't sitting straight or the feeder is crooked and light is escaping
      Ditto that. Check to see if some of your velcro pads are missing. Peel off the platen (velcro attachment), place the pointiest corner into the arrow corner on the index, then slowly lower the DP until the velcro sticks. Then press with your palm to make it stick better. =^..^=
