Kyocera CS 300i freezes up ater 6 prints or copies
  • Jude
    • Oct 2009
    • 256
    Any Kyocera aficionados know why this box will freeze after 6 pages in copies or prints? I swapped out the HDD for a known good one from another box and swapped out the RAM too. Same thing. What's next? Any and all help is appreciated. Thanks in advance. I already have the manual. The machine will run on as if it is paused in print job but won't reset until I turn machine off then back on again.
  • Kyo fan
    • Dec 2013
    • 368
    Re: Kyocera CS 300i freezes up ater 6 prints or copies
    Start by printing event log and analyze error codes you've had to hopefully narrow it down. Are you running any HyPAS software on it?
    • Jude
      • Oct 2009
      • 256
      No Hypass and no error codes. It just runs on til I shut it off.
        • 22999
        Start with firmware. =^..^=
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          does it have a finisher?
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • Jude
            • Oct 2009
            • 256
            BC: I have upgraded to current firmware version.
            Venom: The machine came with finisher but I removed it.
            Thanks guys for heads up. Any other ideas?
            • Venom
              • Nov 2009
              • 765
              Did you install Turbo Firmware? is so try complete package
                • 22999
                HDD, RAM, firmware ... all that's left is the firmware DIMM and the main PWB, each followed by firmware (not turbo). Maybe the operation panel? It's know to be the cause of firmware lockups. Let us know what you find.
                • johnny32
                  • Oct 2007
                  • 102
                  Had a similar problem with a 250ci and after doing all what was stated in the other treads I changed the ip address and it solved the problem. Has been 4 days now and no more problems
                  • Jude
                    • Oct 2009
                    • 256
                    Venom: It does have an internal finisher. Please advise.
                    • Jude
                      • Oct 2009
                      • 256
                      The problem not resolved. There is a correction. The machine has an internal finisher.
                      • Venom
                        • Nov 2009
                        • 765
                        Maybe try with network cable disconnected.....once had similar instance that the switch that the copier was connected to had a network cable with both ends plugged into the switch and caused weird lockups. Maybe an issue with firmware still. Try removing finisher and testing. Try downgrading firmware and testing. If finisher was added after firmware was done then it may conflict. If firmware version made a big jump in versions, then some files may be missing, may need to downgrade then upgrade firmware.
                        • jmaister
                          certified scrub
                          • Aug 2010
                          • 755
                          what are yer printing?
                          any print jobs, any copy attempt does this?
                          Idling colour developers are not healthy developers.
                          • BSGINC
                            • Jan 2012
                            • 19
                            The engine board is most likely bad. I've had this before, mine would run 20 duplex and then just sit and spin no paper feed or jam until I opened a door. replaced the engine board and all is fine.
