4500i folding the leading edge front corner
  • MFPTech
    • 486
    Hi,
    Anyone had this problem please?
    There is nothing that I can see in the paper path, both on the main body and the right door, but I can tell it's after the fuser.
    Cleaned all the rollers and adjusted the solenoid for a bigger gap between the guides of the switch back unit, updated firmware, the machine is leveled ...
    Any ideas please?
    Thanks in advance!
  • Kyo fan
    • Dec 2013
    • 368
    Re: 4500i folding the leading edge front corner
    Replace the fuser, no matter how many prints it has, 1st edition fusers were crap (overall it's a solid line). There are many service bulletins about many changes on the fuser, that it's just cheaper and time saving to replace it completely. I had similar problem where i almost replaced exit unit, but it turned out to be fuser unit.
    • cm79
      • 20
      Kyo fan is right, there is a boat load of updates for those models. Check the troubleshooting guide, there is a few sections in there about lead edge corner folding.
      • Venom
        Technical/IT Support
        • Nov 2009
        • 765
        Ya fuser is bad, as a test try lubing hot roller with silicone oil. Also note km2050 claws fit and may fix problem.
        IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • 23009
          How much lead edge void? I would hope to see 3mm at least. On the machines I've been working on recently its not uncommon to find 1/2mm or less. It leads to a bunch of fuser and post-fuser jams. =^..^=
          • MFPTech
            • 486
            Well, if I run 2-2 I see the 1st side coming out with the folded corner, it goes back in and when it comes out everything looks perfect - the fuser takes care of the fold the 2nd time around!
            • MFPTech
              • 486
              Where do you adjust the lead edge void please (while on the subject so I do not have to check manuals
              • MFPTech
                • 486
                Replaced the fuser and everything ok!
                Thanks!
                  • 23009
                  I believe Paul can help you: Just Manuals, The Internet's largest selection of manuals ~ Instant Downloads
                  • Hawkster
                    • Dec 2010
                    • 19
                    Rather that replace the entire fuser you can replace the sep claw assembly. The film peeling off the claws has been the culprit for me catching the corners. refer to bulletin D159-2LH-0016
                    • MFPTech
                      • 486
                      Swapping claws around fixed the problem.
